Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
3 problems: no home button, locked and stuck in press home to upgrade
My ipad mini 4 has 3 simultaneous problems
  1. Irrepairable Broken home button (but installed assistive touch)
# Locked with passcode ( i remember it)
  1. Stuck in white screen , no assistive touch dot visible saying: press home to upgrade
  2. after battery replacement I want to reinstall all my backed up app and info via itunes. I didn’t know I had to disengage lock and I didn’t know assistive touch would not function while upgrading. Now ipad mini is stuck. Itunes says: could not connect to ipad because it is locked. Enter passcode before it can be used with itunes.
  3. ipad shows no passcode screen but white screen with: press home to upgrade.
  4. it probably started reinstall back-up process and got locked.
  5. tried volume up then together with power till black screen, then release power.
  6. tried 5 presses on power button.
  7. tried volume down with power.
  8. tried all but keeps same comment on ipad and on itunes. Please help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Annelies,
It seems fairly evident that your first step here should be to replace the non-functional home button. You'll lose Touch ID, but at least you can get past the rest of the issue of it being stuck in the update process. You should be able to get a replacement for under $10 USD and that'll let you proceed with the update you're trying to accomplish. Here's the guide you'll need to do that replacement.
iPad mini 4 Wi-Fi Home Button Assembly Replacement - iFixit Repair Guide
P.S. DFU mode would allow you to do an update without the use of buttons or the screen via iTunes, but unfortunately you have to use the power and home buttons pressed together to get into DFU mode, so we're right back where we started with needing to replace the home button.
Don't throw away the old button; once you get your iPad back into an operational state there may be something we can do to help you get the original button working again so you don't lose your Touch ID, but let's address that after you get these issues straightened out.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Annelies van Hagen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 30
Altijd: 315
