Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
89 Vragen Bekijk alle
Making the volume louder than the manufactured setting.
I have my volume all the way up. How do I make the phone even louder?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@michael4114 if you want more volume then the phone is designed to provide, all you have to do is to redesign the logic board circuitry. Design it around the audio amp and the audio codec IC to whatever power that you need it to be.
As you can see this is just not an easy question to answer. If you need bigger volume, get a Bluetooth speaker set up. You can then "crank it up" to your hearts contend.
Was dit antwoord nuttig?
Score 2
I use a UE Boom3 Bluetooth speaker, if you get a second you really can amp it up pairing them
You really can’t push the internal higher as it will fail.
Score 1
Hi
As well as the amazing answers from @oldturkey03 and @danj you could also get a external amp and DAC for your phone and use it with headphones
Hopefully this helps
Any questions please ask
Score 1
Voeg je antwoord toe
MIchael Marks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 118
