Ga door naar hoofdinhoud
Solderen is een methode om twee stukken metaal met elkaar te verbinden door ertussen een ander toevoegmetaal te smelten. Er bestaan vele manieren van solderen, maar dit artikel is bedoeld om je de basisprincipes van het solderen van elektronica te leren.
20 Vragen Bekijk alle
Removing led diode from board
I’m trying to replace dead led’s from my expensive aquarium lights but I am having a hard time removing the led diodes. I’ve tried using a hot air station at 500 celcius (932 Fahrenheit) but the led won’t budge. I tried blasting hot air from both the bottom and top but it won’t budge. I don’t have a heating plate so is there a better way? As you can see the bottom of the board is all metal.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
I find when components won’t budge taking the nozzle from the hot air off and turning the temperature and airflow up a fair bit helps
In your case heating the area of the LED on the underside with lots of hot air should help
Also if you have a soldering iron and ether leaded solder or chip quick(low melt solder) applying ether to the solder joints of the LED will lower the melting point of the solder so that might be worth a shot!
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 2
21 opmerkingen:
@hellomacos I've already tried low melt solder with no luck but haven't tried with the nozzle off. I've never had a component not come off at 500 celcius so this was strange to me that the solder under the diode was not getting hot enough to melt.
door
@ntec
Try heating the board all over until the back of the board is painful to touch(but don’t touch it though)
This could take about 5mins of constant heating if it’s a thick board
After heating try at getting the led you want to heat
If that doesn’t work try flooding the led you want to remove with lots of soldering both sides and use the hot air and soldering iron at the same time
Use the iron to Start melting the solder and the hot air to keep it liquid:-)
Also what are you heating it on top of
Try and keep it off anything that will absorb the heat
door
@ntec @hellomacos it's going to be a beast. The metal bottom is a gigantic heatsink and it'll take a ton of BTU to get it done :-)
Place it on a hotplate at something like 80deg C and get that toasty first.
door
@oldturkey03
Using a heat plate is the best thing for it,it looks to be a thick board too
door
@oldturkey03 Thanks, the board is about 3mm thick. I will look into getting a heat plate.
door
16 commentaren meer tonen
Voeg je antwoord toe
John Nguyen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 359
