laptop wont power up
Our, 2019 Asus 15.6" FHD Touchscreen Thin and Light Chromebook Laptop Computer, Intel Quad-Core Pentium N4200, will not power on. It is completely dead. our daughter only uses it for school. Please advise.
Is dit een goede vraag?
5 opmerkingen
Can you confirm that the Chromebook doesn't work when plugged into a charger (No lights or anything
door Andrew S
That is correct. Will not power up when the charger is plugged in... not 100% if there is no light when the charger is connected. We plugged it in and it would not power up, so then we let the battery drain, plugged it back in to charge and it still wont power up.
door Sarah Earhart
@rungirl Is the charger USB-C?
door Andrew S
@rungirl Can you uload a photo of the charging connector? Voeg afbeeldingen toe aan een bestaande vraag
door Andrew S
Hi
could u please attach picture of charging port and have u tried to use a different charger and could u attach Model Number so you can be assisted further thanks
door John Marasco
