Ga door naar hoofdinhoud
Dit model van de G15 heeft een mat 1080p-scherm met een verversingssnelheid tot 360 Hz, Intel i5 tot i7 11800H-processors, 11e generatie UHD-graphics en een GeForce RTX grafische kaart.
Storage space low for no reason
I recently got a Dell G15 5520 that's running Windows 11 with a Core i7-12700H 16 GB memory, and I use it for both gaming and research, because my old one was excruciatingly slow. I haven't had it for a month and the disk space is already low, even though last night I checked it, and it was 227 GB of 453 GB free. Now it's 56 GB of 453 GB free! I ran both defragment and disk cleanup, neither worked. Settings say temporary files are taking up 212 GB, installed apps 65 GB, and other 34 GB. But when I go into temporary files, it only shows 24 GB of stuff, including the downloads folder. I'm Starting to think it's an unfixable virus or something, because my antiviruses WOULD NOT detect anything (I have both McAfee LiveSafe and Malwarebytes Premium). Soon I'll just put all the stuff I care about on a hard drive and factory reset the thing. Please help soon! 🙏🙏🙏
Is dit een goede vraag?
5 opmerkingen
Hi @anchefixes,
What does it show if you delete the 24GB of temp data and then check?
Did you search for %temp% in the search box on the desktop to find the Temp folder?
Also check how much is kept stored for Windows Updates and see if you can delete some of them to create more space.
door
It then shows 12 MB of other temporary files. 129 MB is kept for windows update
door
PS: can you change that comment to an answer so I can accept it 😀
door
@anchefixes
Done
Cheers
door
انا عندي نفس الجهاز والمراوح بتشتغل بصوت مرتفع وساعات اللاب توب بيقف
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@anchefixes
So is the temp file now down from 212 GB to 12MB when using the method you first used as posted in your question?
Presumably Disc Cleanup still doesn't work OK?
If so run an sfc /scannow command and check if it finds and fixes any errors and then run Disk Cleanup again and check
To run the command : In the search bar, type cmd. select Run as Administrator. In the command prompt window, type sfc /scannow and press Enter.
Yes there is a space inserted between the sfc and the / symbol.
If still no good try a DISM command.
From the command window as above type dism /Online /Cleanup-Image /RestoreHealth then press Enter and wait for the result.
This is old world computing, the mouse doesn't work in the Command window. If you make a typing error use the backspace key to step back and delete the error and then start typing again.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
IT WORKED! Command prompt fixed it! The sfc /scannow command revealed 2 problems with disk cleanup, now it works perfectly! Thank you so much!
door
Voeg je antwoord toe
Anchevauls Walker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 1,283
