Ga door naar hoofdinhoud
Reparatiehandleidingen en -informatie voor de Nintento Switch Joy-Con controllers.
167 Vragen Bekijk alle
trying to replace case on nintendo switch joy cons
so long story short im trying to replace the casing on a set of joy cons and the casing that i bought... doesn't have a instruction manual in the box ._.
the rear casing won't come off after unscrewing all the screws also
help???
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
https://www.youtube.com/watch?v=ymBbKWzL...
Was dit antwoord nuttig?
Score 1
Hello. I believe that the ifixit guide for joy cons might help. They explain how to take them apart and disassemble it.
Just use the part where they talk about joycons
Nintendo Switch Teardown
Score 1
Did you remove the rails before you took out the screws? The back plastic should come off relatively easily.
Be sure to open it like a book with the part that slides into the switch as the books spine.
Check out this guide for how to get into the case.
Score 1
Voeg je antwoord toe
timtom77 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 80
