Ga door naar hoofdinhoud
Schematics and pictures of circuit board. Very often the wire feeder stops working because of dead relay. You can replace the defective one with a more durable 8A relay.
I don't understand the 8 levels
I don't understand the 8 levels for volts and amperes. Do you have idea for calculate ?
Is dit een goede vraag?
1 Opmerking
bolliriduilio post a picture of where you see those Volts/amps chart with your question. What exactly are you asking? Mig Welding will depend on your wire, the type of metal you are trying to weld and the thickness of the metal etc. Give us more of an idea what information you are looking for. Also, what make and model welder are you using (PrimeTech Mig 200?)
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
lowest to highest power
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
bolliriduilio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 18
Altijd: 189
