Ga door naar hoofdinhoud
A 13 inch notebook-style laptop created by HP in December 2011. Its dimensions are 12.54in (31.9 cm) x 8.67in (22cm) x 0.7in (1.8 cm) and its weight is 3.3lb (1.5kg).
Help identifying correct battery replacement
The laptop model number above is incorrect but the correct one wouldn't come up.
The correct laptop model is 13t-d100, the laptop part number is M2K14AV and the SN is CND6389KSW. I believe the HP laptop battery model is 816238-850 (Battery - 3-cell 45WH 3.83Ah LI (VR03045XL-PL)) but i need help confirming what to buy.
Thanks.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@markez I've checked the maintenecae manual as well as with HP and that number looks absolutely correct. You may get more reassurance if you ask wherever you are going to purchase it from. If still unsure, get the numbers from the old battery to compare it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Mark Ezrin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 90
