Erratic behaviors and reboots yet sometimes works fine?
Samsung QN70Q6DTAFXZA, latest firmware updated. Images uploaded are examples of graphical errors it occasionally displays. So if I get home from work and turn on my tv it works fine for a few minutes, pull up a 4k youtube video and scroll the menu a bit. After a few minutes of this it will reboot. When it boots back up the problems begin. Stuttered boot up, lines appear on image, reboots as soon as remote is used. I've tried disconnecting each side of the panel but there are no boot issues when disconnected individually. Ocassionally it will turn on and begin faulting immediately and sometimes it takes more than 5 minutes. The image quality is flawless until these issues flare up. Once they do they won't go away until it's been unplugged for 30 or so minutes. It also seems that when I start using the remote a lot(flipping through menus etc.) it can trigger the issues. I'm thinking at this point with this many sporadic issues it may just need a new mainboard. Any thoughts? I'm going to be testing the voltage on the mainboard tonight.
Is dit een goede vraag?
4 opmerkingen
Hi @zakh4111,
Try removing the back cover and use a fan to blow air on the boards Try to direct it to one board at a time.
Just to eliminate if it is an overheating problem i.e. component running hot when it shouldn't be
door jayeff
Thanks for the reply. I've noticed the shield over the cpu is quite hot to the touch after just a few minutes. I'm used to working on computers and unsure if this is normal for the processor on a tv. This model has a single main board that connects directly into the panel board where it then splits to each side of screen with "C" ribbon. What would be a normal operating temperature? I've checked and it does have a small thermal pad between cpu and the shield.
door Zak Hyvarinen
@zakh4111
I don't know what the normal op temp would be but if it remains stable when being cooled, then it's a start to finding out what's wrong.
Does it remain stable with no inputs/outputs connected and you just turn on and scroll through the TV settings menus?
Just trying to eliminate if an input or output may be the cause of the problem i.e. signal source or perhaps things like one connect box or hdmi-arc connection etc
door jayeff
Alright I'll cool down the cpu tonight and see if I can get it running for more than a few minutes. I am doing all testing with no inputs. It is the tv's own menus that I was scrolling through to help trigger the issue. I will update later once I've tested a few of your suggestions. Thanks
door Zak Hyvarinen
