Ga door naar hoofdinhoud
De Xbox 360 wireless controller werd uitgebracht op 22 november 2005 en is de primaire spelcontroller voor de Xbox 360-spelconsole van Microsoft.
Battery board has rust and doesn't work
So I recently found out that my 360 controller is very rusty on the back and especially on the battery board and it just won't turn on anymore like the old days. Any help is highly appreciated. Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @stroft2
"Rusty" sounds like a battery may have leaked and corroded the battery connection terminals or water has penetrated the controller at one time and done the same.
Remove the battery from the controller and then disassemble the controller and clean the terminals (and anything else) using a Q-Tip slightly moistened (not dripping) with Isopropyl Alcohol 99%+ (available at electronics parts stores).
Once the terminals are bright and clean (if there's any left that hasn't been corroded away) re-assemble and insert a new battery and check if it works OK.
Here's the Xbox 360 Wireless Controller-onderpaneel vervangen guide that may help.
Here's the rest of the controller repair guides if you have to disassemble it further. Xbox 360 Wireless Controller
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
stroft2 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 54
Altijd: 3,053
