Ga door naar hoofdinhoud
2.3L 4cyl or 3.0L V6, 6th Generation
I cant get any spark , I replaced my cap n rotor notsure if its my co
No spark at all i replaced the cap n rotor im not sure if its the coil or the ignition module?
Is dit een goede vraag?
1 Opmerking
mattcannon48 what engine size does your Accord have?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I know it's a different make/model than my own vehicle, but when I couldn't get any spark it was the icm for me. Located inside the distributor. I posted a pic of yours so you can see where it should be.
Was dit antwoord nuttig?
Score 1
I think there are several common-ish causes for this symptom. Without additional details of what all has been tried,. here are a few thoughts and some supporting links:
-bad key code
-Bad ignition coil(s)
-bad plug(s)
-damaged cam position sensor
-broken timing belt
https://www.google.com/search?q=1998+hon...
Voeg je antwoord toe
mattcannon48 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 133
