Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
2008-2010 Audi A3 Quattro Sportback/Hatchback 2.0L L4 Turbocharged. Deze apparaatpagina is gebaseerd op de 2010 Audi A3 Quattro Sportback/Hatchback 2.0 L4 Turbocharged en is compatibel met Audi A3's van 2008 tot 2010.
Inconsistent cold start idling
Every morning when I start my car it makes a weird noise when idling, but after it warms up the noise seems to disappear. Any suggestions on what it might be?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi justinjdk1910,
Is this a sort of a "screeching" sound? (Very hard to describe via text..)
If that is the case, it could be a slipping fan belt or auxiliary belt. This is the first suspect when diagnosing a screeching sound from the engine bay, that goes away after a little while when the engine gets to temperature.
If you could, could you try and get the sound on a short video clip, and then upload here on iFixit and update your question with that clip? Here is a guide on Adding images to existing questions
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
Hi Geir Ove Andersen
it is not a screeching sound, but more of a clicking sound. I will record a short video clip tomorrow and upload it.
door Deel
@justinjdk1910 Alright, it’ll be interesting to hear that clicking. My first suspect with clicking, is from the starter itself, but that would only click while the key is fully “turned”. Another source of clicking is from belt wheels -/guides. Those have bearings and can produce a clicking that goes away, at first, but as the wear gets worse the noise will stay.
door Deel
It seems I am not able to upload my video and I tried everything, an error keeps showing?
door Deel
@justinjdk1910 Hmm.. You could upload as private video on YouTube and share link?
door Deel
Do you perhaps have What's app? Then i can send you a private video.
door Deel
1 commentaar meer tonen
Voeg je antwoord toe
justinjdk1910 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 35
Altijd: 1,645
