Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor gas- en elektrische warmwaterreservoirs, boilers en huishoudelijke warmtewisselaars.
pressure release valve leaking
how to replace the valve
Is dit een goede vraag?
1 Opmerking:
Hi @tongrick,
What is the make and model number of the water heater?
Have you operated the release lever on the pressure relief valve so that it opens to release the pressure in the tank, then release the lever so that it closes again and check if it stops leaking?
It may take a few minutes to stop dripping until it finally closes fully again.
door
Voeg een opmerking toe
1 Antwoord
pressure relief valves do develop leaks and can be easily replaced. However, after my neighbor did that his tank started leaking. The two were not connected, the heater was just old.
Was dit antwoord nuttig?
1 Opmerking:
Thank you for the answer.
door
Voeg je antwoord toe
RICHARD TONG zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 27
Altijd: 370
