Ga door naar hoofdinhoud
Rear USB port repair
I have accidentally shorted one of my USB port when tried to plug in the type c cable, Where can I find e.g. the fuse to repair it?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi,
Unless you get a better answer an option to consider is to purchase the schematics for the laptop. (example only - I couldn't find a free download online, you may have better luck)
They will show you how the port is powered.
If the motherboard board number is NM-A451 search online for NM-A451 schematic to find suppliers of the schematic that may suit you better than the one I linked
Was dit antwoord nuttig?
Score 1
Gergely Hunyady we do need a better description from you about which port and what you have checked etc. I can really only find one fuse for the USB and it's located between the ports. Check it with a multimeter for continuity. Let us know what you find and more information is definitely needed.
This view is to make sure you can find the location a bit better.
Score 1
Voeg je antwoord toe
Gergely Hunyady zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 289
