Ga door naar hoofdinhoud
Een desktop-pc die is gebouwd met kant-en-klare doe-het-zelfonderdelen, in plaats van een kant-en-klare pc van een grote fabrikant. Deze kunnen ook door een systeemintegrator worden gebouwd met kant-en-klare onderdelen.
New psu not workin
Afbeelding
Afbeelding
Hi, i recently upgraded to a 3060ti and with that a New psu but with it my pc is not turning on, whenI try with my old psu my pc still works fine but not with the New one, i have tried reseating the cables many times but no succes, when i plug the New psu into the wall my gpu/psu fans start for a brief moment and then stop again and pc wont turn on, any help?
Is dit een goede vraag?
Score 2
14 opmerkingen
@finiego what are the make and model of your old PSU and same for your new PSU?
door
@oldturkey03 no they are not
door
@finiego @oldturkey03 was asking what the make and model is of both your old, and your new PSU
door
@geirandersen thanks brother :-)
door
@oldturkey03 oh sorry, the old one is FSP group Inc and the New one T.F.skywindintl both server psus, because my case is small
door
9 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@finiego I’d seriously suggest getting a multimeter(maybe borrow one from a friend). It must be able to measure DC voltage (just about every digital multimeter does). Connect the old PSU to power (doesn’t have to be in the PC) and measure each pin. You need to find one GND and put the black probe on that. Then go over every pin and check with the red probe. That should read either 12V, 5V or 3.3V (only on the new PSU!). Write it down, I like to draw a picture of each plug and write voltages on each pin, with arrows.
The do the same on the new PSU. Once complete, compare the readings and see if everything corresponds.
The old PSU only had 12V and 5V, while the new one also has 3.3V
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Fin Faas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 27
Altijd: 511
