Ga door naar hoofdinhoud
De Xiaomi Redmi Note 9 is een mid-range smartphone van Xiaomi die in april 2020 werd uitgebracht. Het toestel heeft een 6,53" IPS LCD-scherm, een 48 MP hoofdcamera, een vingerafdruksensor aan de achterkant, een 5020 mAh-batterij en draait op een MediaTek Helio G85.
Device reboot continously when in Standby-mode
Good Morning,
i have the phone of my mother in law and it's rebooting continously when in standby. as long as the display is on, you can use the phone normal, but after locking it device starts to reboot again and again. did someone have this before?
btw: Chargng is a little bit slow, but i think it's because of the reboots (more power needed).
Is dit een goede vraag?
Score 1
3 opmerkingen
Have you tried to update software or firmware? It could maybe be a Internal Issue but im not sure what would cause it.
door
this is impossible, because when i tried it it fall back to bootloop at 64% Updated.
door
non of the above works i have tried power and volume+ button but it is not going on that
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@m0ddmylife
What happens if you start the phone in safe mode?
If still no good, here's a link to the schematics which may help as it has Level 1, 2 & 3 repair instructions.
I haven't tried this link but have used the website before for other makes and models and they were OK.
Was dit antwoord nuttig?
Score 1
Your smartphone might experience a reboot loop if its cache memory is full. To test for that possibility, you should empty your phone's cache
Regards,
Will
1 Opmerking:
I've set it back to Factory mode multiple times, so this is not working.
door
i have a had the issue a couple times what i do to fix this is, is to hold the power button until the lock screen appears
Voeg je antwoord toe
Michael Kastner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 33
Altijd: 1,455
