Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Apple's topsmartphone voor 2020. Aangekondigd op 13 oktober en uitgebracht op 13 november, de iPhone 12 Pro Max is voorzien van een 6,7" oled-display, een drievoudig camerasysteem achteraan met LiDAR en 5G-connectiviteit. Opvolger van de iPhone 11 Pro Max.
Guide for replacing lightning port
Hi, I see you sell the part for replacing the lightning port on a 12 pro max, but I can’t find and ifixit guide on the subject, is one available?
I’ve had the phone since launch, it’s now stopped charging unless placed in a specific position, I’ve cleaned the port, tried multiple cables and chargers with no luck, I’ve only ever used MFI certified anker or apple cables. Is there anything else I can try?
Is dit een goede vraag?
Score 2
1 Opmerking
Other than replacing the iPhone 12 Pro Max Lightning Connector Assembly I can't see any other answer.
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi
As @danj had said ,it’s probably time for a new lightning port
However
When you cleaned it did you clean it properly,I suggest you look at it again and use a pair of fine tipped tweezers or a seeing needle to clean it and finish it off with some isopropyl alcohol
Iv seen many lightning ports that claim to have been cleaned but they aren’t cleaned properly
If that doesn’t work it’s time for a new port
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
Thank you for your advice!
I did use a pair of fine tipped tweezers but will try some alcohol.
How do I request a guide on how to do this from ifixit? It makes no sense to me that they sell the part but have no guide
door Deel
@telstar17
Unfortunately I think all you can do is request they make one over on ifixit meta(linked below)
https://meta.ifixit.com/
If it comes to replacing the port I can get you one if you would like but it won’t be from ifixit:-)
door Deel
I will do that!
I just tried the isopropyl alcohol and fine tipped tweezers and was shocked how much rubbish came out, I’ve never had so much in there before and have always managed to clean it with just tweezers. It seems to be charging much better! Thank you so much for your help!
door Deel
@telstar17
Your most welcome!
Please let me know if there’s anything else I can help with:-)
door Deel
Hi, im also facing the issue. Is there any way I can get a charging port fairly cheap?
door Deel
1 commentaar meer tonen
As Said By Dan, I don't think any other option exist better try replacing the post before it transcending
Score 1
Hi John,
Glad to hear you got your phone working again without having to replace the charging port!
Just for future reference for you or anyone else looking for a guide, although there isn't one here in iFixit yet, there is a French site called SOSav that does have a very usable guide for replacing the iPhone 12 Pro Max charging port. There are some idiosyncrasies in the translation such as calling flex cables 'tablecloths' and Phillips screws 'cruciform', but outside of those it's very usable.
Charging connector iPhone 12 Pro Max repair - Free guide - SOSav
Score 1
i found a youtube video on how to do it hope this helps
https://www.youtube.com/watch?v=dSy_kjkR...
Voeg je antwoord toe
John Kelly zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 166
Altijd: 12,005
