Ga door naar hoofdinhoud
Het De'Longhi BCO430 koffiezetapparaat is een combinatie van pomp-espresso en 10-kops koffiezetapparaat met opschuimstok, zilver en zwart.
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Afbeelding
Afbeelding
Afbeelding
Did these images come ok?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 1
8 opmerkingen:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
door
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
Voeg afbeeldingen toe aan een bestaande vraag
door
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
door
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
door
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
door
3 commentaren meer tonen
These coffee makers often are similar. Compare to Saeco Magic Cappuccino SIN017 boiler verwijderen and Starbucks barista , perhaps it helps. Good luck!
Starbucks Barista Afbeelding
Handleiding
Demontage van de Starbucks Barista
Moeilijkheid:
Gemiddeld
Saeco Magic Capuccino SIN017 Boiler verwijderen Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
Score 1
Pics attached - this is how far I could get
Update (10/08/2022)
Update (10/08/2022)
Afbeelding
Afbeelding
Afbeelding
Voeg je antwoord toe
liluet_hernandez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 466
