Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage-informatie en probleemoplossing voor de Logitech Wireless Desktop MK710 (uitgebracht in 2013).
Water damage of LogitechK710 keyboard
I have a logitech K710 keyboard that I spilled a water on the keyboard 2 weeks ago. I immediately turned it over and drained the water, I set it to dry for a day (flipped over), and then I took all the keys off and dried any moisture left. But still there are certain keys that aren't working, most importantly the space bar doesn't work. What's the next step? I'm hesitant to take it into get repaired as it was only a $60-$70 keyboard/mouse set.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
The best thing to do here is to open it up and give everything a good clean with isopropyl alcohol and some cotton buds/q tips
When water comes into contact with electronics it can cause it to corrode which can cut the flow of electricity
Once fully dismantled and cleaned inspect for any burn marks and broken traces as if you find any you can restore them by running a jumper wire or using diver conductive paint
Once open if you could upload some photos using this amazing guide it would be amazing
Voeg afbeeldingen toe aan een bestaande vraag
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
wrestlerxtr1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 357
