Ga door naar hoofdinhoud
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
Requesting iPad 7 WiFi NAND Area Diode Mode Readings
Hello Everyone!
Please help me with iPad 7 WiFi NAND area diode mode readings.
Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
On the chance that you still haven’t found this yet, I use this website for Diode mode readings often, but it’s only really got connectors. So not NAND. But I have a spare known good of this model, I will see what I can get for you in the morning,
https://logi.wiki/index.php/iPad_Diode_M...
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
@flannelist
Thats amazing!
I was trying to find a schematic for them but could only find payed ones that didn't come with a board view files and only schematics
il let them know you have solution
door
@flannelist thanks a lot, it will be very helpful to get readings from good board. @hellomacos
door
Hi
Do you have a schematic for it?
If you do that schematics tell you the size
Or
If you want to post some photos using this amazing guide
Voeg afbeeldingen toe aan een bestaande vraag
I could use the photos the photos to try and tell what size they are
Hopefully this helps
Any questions please ask
Score 2
17 opmerkingen:
I don't have schematics. I want to check on logic board if NAND points are properly connected to other areas. hence I want to know diode mode readings for NAND area.
door
@hellomacos I don’t think it’s about the diode but checking for a short on a circuit in diode mode on your multimeter check on here for the how etc
door
@v1ny4
I see
I would check places like the badcaps forums for schematics as they’re a few for a verity of models on there on there
When you said measurements I thing you meant measurements like 0402 0201….
Il have a look my self and see what I can find
Also what is the Board number you are working on?
door
@oldturkey03
I just realised that
I though they were on about components sizes because he said measurements in the original post
Thanks for letting me know:-)
door
@hellomacos my bad, sorry
door
12 commentaren meer tonen
Voeg je antwoord toe
Vin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 742
