Ga door naar hoofdinhoud
Released in 2019, the XPS 13 7390 is a 13-inch traditional laptop with a 10th-generation Intel Core processor inside. Don't confuse this laptop with the XPS 13 7390 2-in-1, which is similar but has a 360 degree foldable display.
4 Vragen Bekijk alle
Battery replacement for the XPS 7390 model
I can see you have the Dell XPS 13 9343/9350 Laptop Battery replacement available, will this work with the XPS 13 7390 model? I'm having a !&&* of a time finding a reputable seller and some guidance would be greatly appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Ifixit gives a 1 year warranty on the battery, which is better than most.
If it doesn't work then at least you will get a refund or a new battery
Scroll down to description and warranty. Also see Shipping restrictions on the page
Replace a 52 Watt Hour (Wh) battery compatible with select models of Dell XPS 13 laptops. Afbeelding
Product
Dell XPS 13 Battery - DXGH8
$98.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kingsley Gittins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 430
