Ga door naar hoofdinhoud
The Dell XPS 13 7390 is a compact, lightweight laptop from 2019 that features a 10th Generation Intel Core processor, a 13.3-inch InfinityEdge display (often 4K UHD), and a slim, sturdy aluminum chassis. Highlights include strong performance for its class, Wi-Fi 6, and robust connectivity via two Thunderbolt 3 ports. Critics state it relies heavily on USB-C and lacks a traditional USB-A port. Don't confuse this laptop with the XPS 13 7390 2-in-1, which is similar but has a 360 degree foldable display.
Battery replacement for the XPS 7390 model
I can see you have the Dell XPS 13 9343/9350 Laptop Battery replacement available, will this work with the XPS 13 7390 model? I'm having a !&&* of a time finding a reputable seller and some guidance would be greatly appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Ifixit gives a 1 year warranty on the battery, which is better than most.
If it doesn't work then at least you will get a refund or a new battery
Scroll down to description and warranty. Also see Shipping restrictions on the page
Replace a 52 Watt Hour (Wh) battery compatible with select models of Dell XPS 13 laptops. Afbeelding
Product
Dell XPS 13 Battery - DXGH8
$79.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kingsley Gittins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 563
