Ga door naar hoofdinhoud
The Toyota Tundra is a pickup truck manufactured in the United States by Toyota.
18 Vragen Bekijk alle
2000 Toyota Tundra Limited 4.7L issue
I’m trying to troubleshoot-diagnose my 2000 Toyota Tundra Limited 4.7L issue.
The engine shuts off when I put it into gear ⚙️ D or R; but, stays on in N.
I’ve been told via mobile mechanic it’s possibly a bad solenoid in transmission or torque converter/throttle plate.
Searching websites and DIY on YouTube.
Please advise any directional arrows you might know!
Is dit een goede vraag?
4 opmerkingen
I suggest searching Toyota Tundra forums with members owning and sharing info. They may be more experienced in answering TT problems unless a resident expert here with TT expertise can answer this question.
door
Thank you 😊- ok, Toyota Tundra Forums! Do you know of any such Forums? —IF so, please post a Link in your reply! 🧰⚙️🔧
door
Thanks 🙏🏼 again.. I will surf’m for insights upon my profit walk! —Cheers!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I'm guessing the transmission is locked up. Putting it into gear stalls the engine because it can't turn the torque converter.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
So, iF torque converter can’t work, what has to be actually done to “UNLOCK” it? Specifying how much labor and parts do I need to BUDGET for? Thx for your time and profitable directional arrows! 🤑
door
Voeg je antwoord toe
Jays2000ToyotaTundra zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 66
