Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
How to remove the Passcode with out losing data?
I’m the owner of the device and the Apple ID being used on the device I just forgot the passcode from it and it’s also currently with the “iPhone disable connect to iTunes ”sign from trying every number I could remember lol 🤦🏻‍♂️
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
use 3utool and reflash with retaining user data
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
The device is in disable mode would I have to get the device into dfu mode for the device to connect to 37tools and follow your suggestions?
door
@taco18 dfu or recovery mode
door
@tech_ni thanks for your help I tried following the steps to get the device in DFU mode, then flash process maintaining user's data I still find myself in need of a passcode even on the attempt to retrieve user's data and once I use a passcode I believe it's correct the phone gets into an iPhone unavailable try again in some minutes. If there's anything you know I should do to get rid of the passcode please help once again
door
Put it into dfu. Recovery resets after 15 minutes turning the phone on losing the connection to pc, dfu doesn’t.
Score 1
Waimond michae
Update (11/14/24)
Sign out apple
1 Opmerking:
Sign out apple
door
Voeg je antwoord toe
Taco zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 296
