Ga door naar hoofdinhoud
De SanDisk microSD-kaart is een opslagmedium in het TransFlash/microSD-formaat. De standaardmodellen zijn verkrijgbaar in verschillende capaciteiten, tot 2GB. De kaart werd uitgebracht in oktober 2001.
What information should I put?
I'm trying to see all the past photos and videos of my SanDisk MicroSD Card 2GB trough USB in Windows 10, but it says I need to "Format" it first to use it, but I am confused on what setting I should insert, (Specially the "Volume" ).
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
Do not format the card!
If you do a full format on the SD Card, you will lose all your files (photos and videos) that are stored on the card. They will be erased.
If you do a quick format, the file address table on the card will be erased, which is essentially the same thing as you won't be able to retrieve files, at least not easily.
If Win 10 shows that the card needs to be formatted it can't read the card so either the card is faulty or corrupted or the USB SD Card reader may have a problem. Can you read other SD Cards OK using the card reader?
Where was the card previously inserted? If it was a camera can you view the files from the card in the camera at all?
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Omali Y. Martínez Rivera zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 315
