My fan is making so much sound while rotating, what should be the prob
Fan making sound while rotating
Is dit een goede vraag?
Hi
I would first take it off the ceiling and take it apart til you get to the motor and make sure the baring isn't stuck and spins freely
also while you are checking it I recommend putting some form of grease in it to help it spin
if that doesn't work if the motor has carbon brushes I would check them to see if they look heavy warn as this can cause this issue too
Hopefully this helps
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 48
1 Opmerking
A description of the sound would be most helpful. Grinding? A sort of squealing or squeaky sound?
door brandon k
