System Error (Focus) any advice?
Can't get past this message on start up. Any solves?
Is dit een goede vraag?
christopher.stollery this is commonly caused by a stuck lens. It is possible that teh lens mechanism got "knocked off" it's track or other grit getting into the camera mechanism. First I would remove the existing batteries and the memory card from the camera, wait one minute and then put the batteries and the memory card back and turn the camera on. If that does not work you could try a vacuum cleaner and apply some suction around the lens case. Some people swear by using a piece of paper around the lens area and move it around the gap to possibly dislodge anything stuck in there. Check on here for more ideas. If none of that works, consider replacing the lens. Disassembling Panasonic LUMIX DMC-LX100 - iFixit Repair Guide
Was dit antwoord nuttig?
I just removed the battery and the SD card, then put it back after a moment and voila! It works great!
I pressed and held the menu/set button then turned the camera on. That cleared the problem.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 73
Altijd: 8,092
