Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Chromebook 4, uitgebracht in oktober 2019, beschikt over een 11,6"-display, een Intel Celeron N4000-processor en 32 of 64 GB eMMC-opslag.
How can I replace my battery
How can I replace my Samsung chromebook battery?
Is dit een goede vraag?
1 Opmerking
Which screwdriver is needed for battery connector?
door Deel
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
Assuming we're still talking about the Samsung Chromebook 4, then a standard Phillips screwdriver should do the job, at least according to this photo I found.
https://preview.redd.it/bzl4f58rgxt51.jp...
Was dit antwoord nuttig?
Score 2
Hi
Im not quite sure about this specific model but I do know that chromebooks in general are quite easy to work on as there isn't a lot going on inside
I would say its as easy as taking the bottom panel off, unplugging the battery connector(look for the battery cable to find it),unscrew the battery
and that's about it, iv done this process before on a schools dell Chromebook and that's how I did it
if you need any step by stem help please don't hesitate to ask me or anyone else here
Score 1
Hi @xaviertoo
Here's a video that shows how to open the laptop to replace the battery in a Samsung Chromebook 4.
The battery model number is printed on the battery. Search online for (insert model number) battery to get results for suppliers that suit you best.
Score 1
Voeg je antwoord toe
Paul Xavier adams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 1,394
