Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Mac Pro uit begin 2009—ook wel bekend als de Mac Pro 4,1—introduceerde in maart 2009 de Nehalem-architectuur van Intel in Apples lijn van professionele desktopcomputers. De Mac Pro 5,1 gebruikte hetzelfde interieurontwerp, maar kreeg verdere CPU-updates in 2010 en 2012.
Is this CPU compatible?
I know about delidding the CPUs for the 4,1 (which I have) but will the X5675 on this page work?
Here it says it will work,
But do I have to find a delidded version?
@oldturkey03
Is dit een goede vraag?
Score 2
12 opmerkingen
@beanman56 probably be easier that to match the heatsink like this http://forum.netkas.org/index.php/topic,... but will cost you way more
door Deel
Ughh.. could I just get a heat sink from a 2012?
door Deel
@beanman56 probably not. To easy :-) Just shim it. Couple of washers and you'll be set.
door Deel
so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
door Deel
@oldturkey03 - so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
door Deel
7 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hello @beanman56
Apologies in advance but I am not Oldturkey03
But I do know that the cpu will work in a Mac Pro 4,1 BUT ONLY IF YOU FLASH IT TO 5,1 I cannot stress this enough,in order for this to work you need to do it
As for de-liding people really like to charge a premium for delided cpus so I would order a deliding vise and to it manually
I have a 5,1 and it has the Intel Xeon X5675 so just a little more assurance for you :-)
Hopefully this answers your question
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Uhh, I'm not that confident in being able to do it.
Thanks for trying.
door Deel
No worries:-)
door Deel
Voeg je antwoord toe
Ben Capehart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 593
