Ga door naar hoofdinhoud
Repair guides and support for phones manufactured by Oppo Electronics Corp.
452 Vragen Bekijk alle
I think my phone (oppo a5 2020) got wet...
I picked up my phone and I just saw that the screen looks like it got wet. I tried to wipe it off but I noticed that the damage was inside the phone. It accidently slipped from my hand and the damage is now bigger. What do I do with it? I'm scared that my mom will find out about it.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@usingk that does not sounds good. Time to have a talk with your mom. There really is no easy way dealing with it. If your phone got wet then there are few things you should do.
For now your want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your iPad. Use something like this video to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your Oppo as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned with an ultrasonic cleaner. After this you must replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate.
Not sure what damage your phone received when you accidentally dropped it, You would have to tell us more about that. The linked video should help you with all those repairs too.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
wobi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 394
