Ga door naar hoofdinhoud
De Anker Soundcore Flare Mini is een kleine, draagbare Bluetooth-speaker die ontworpen is voor gebruik tijdens het reizen, buitenshuis of in huis.
Powerbutton broken from motherboard
Afbeelding
Afbeelding
These are the pieces I found inside the speaker but can't figure out how to fix it.
Afbeelding
Afbeelding
Any suggestion would be a great help.TIA
Is dit een goede vraag?
Score 4
3 opmerkingen
I need help also for this exact same problem. I accidentally disrupted the power button somehow and now the only problem I have is I've poked the power button so much with pencils, needles, Bobby pins, and similar small utensils like that ,that at one point allowed me to power it off and on until one day I stopped working. Is this fixable? Please I need someone's help so desperately this is my one and only blue tooth speaker I have . I can't afford a new one I'm unemployed I have been and I just after 6 years of waiting for a disability approval check finally getting approved starting January 2023 . So I still have some time that will be without my music speaker😞.So if someone can please give me any ideas on how to fix this problem I will be eternally grateful to to you🙏
door
Was this ever fixed? I got same issue.
door
I also have same issues
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Dear just take a small on/off button and soldier it with 2 points.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
What do you mean? Can you please explain that to me more in detail? Thank you I will appreciate it it very much friend
door
Voeg je antwoord toe
Mahbubur Rahman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 1,173
