Ga door naar hoofdinhoud
De Xbox Elite Wireless Controller Series 2 werd uitgebracht op 4 november 2019 en is compatibel met Xbox One-, X- en S-consoles, evenals pc's met Windows 10/11. Model 1797.
Left stick drift and delayed response time
The left stick is always drifting. Sometimes it's not noticeable in game but in menu it will cycle up consistently. Sometimes a quick flick fixes it. Other issue is you press the stick in and the action is not always crisp, there is a delay
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
connect the controller to a pc or laptop then open this site, https://gamepad-tester.com/. it will show you how bad its moving. if bad it needs the analogue stick replaced.
Was dit antwoord nuttig?
Score 2
Hey Tyrone! I was able to fix it by opening up my controller and cleaning the sensors on the left stick. This helped me a ton.
When you get to step 11, make sure you move both the green plastic housing for the left stick's sensors. The one on the right controls the X axis and the one on the bottom controls the Y axis. You most likely need to clean out the bottom sensor with some canned air and it should work.
Saved me a few hundred bucks by not buying another controller! Hope this helps out!
Een analoge stick-drift in een Xbox One Elite Series 2 controller repareren
Score 1
i replaced the analog stick but the problem persisted. i think it might have something to do with a capacitor
Voeg je antwoord toe
Tyrone Palmer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 46
Altijd: 4,473
