Ga door naar hoofdinhoud
Reparatiehandleidingen en specificaties van de HP Envy 17t, uitgebracht in 2017. De HP Envy 17t heeft een 17"-scherm, 16 GB RAM en een Intel Core i7-processor.
Why is my computer overheating while off completely?
I have an HP Envy 17t that is a few months over a year old and the problems that it has started a few months after and Hp customer support is no help, the main issue is that it will be completely shut down and it will overheat to the point of burning my hand. I have tried everything that I know to try and find the issue to the extent of making it a brick with no software on it, then reuploading it. I have also found that when I open the lid the lights will sometimes be on as well, and it kills my battery. I am now desperate for information on this problem, because I have thought of everything I know, and it hasn't helped.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There's a couple of things you're going to want to do.
  • Make sure that your machine's air vents are clear of any debris or dust
  • Open the device up and make sure that the cooling fan is clean actually running
  • Ensure that your CPU's surface is clean and has a proper amount of thermal paste.
I did find a guide on how to get into the device to inspect the internals. I'll link it here, but you'll only need steps 1 - 11. I'd also attach pictures if you do get the opportunity.
iFixit Afbeelding
Handleiding
Voeg afbeeldingen toe aan een bestaande vraag
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
HP Envy 17t Beeldscherm Afbeelding
Handleiding
HP 17t-k000 Series Beeldscherm vervangen
Moeilijkheid:
Gemiddeld
1 - 2 hours
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Justin Boge zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 311
