Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
1.5 Core Solo-, 1.66- of 1.83-Core Duo- of 1.83- of 2 GHz Core 2 Duo-processor. Dit dekt de eerste op Intel gebaseerde Mac mini-modellen van begin 2006 tot medio 2007.
Mac mini 2007 dead
Hi everyone,
I recently bought a dead Mac Mini from 2007. But when I try to power it on, there is nothing, no light, no chime, not any sound from it. I took apart the logic board and everything seems fine. The charger is working because on the second one i have, it works perfectly.
Do you have any suggestions to measure with multimeter ? Because I’m used to laptops not Mac Mini’s. Thanks :)
Update (03/24/2022)
On the global photo, it’s at the top right
Afbeelding
Afbeelding
Is dit een goede vraag?
5 opmerkingen
Can you take a second picture so we can at least read the logic board labels and the cap if its still intact in the location it was located.
door Deel
@danj hello, i removed the capacitor the motherboard is a 820-1900-A from 2006.
door Deel
It has the same size as the others next to it @danj
door Deel
@anthony10006 - Just because it looks the same doesn't mean its the same values.
door Deel
Yes i know. Unfortunately, i can’t find any schematic for this board :( @danj
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Le problème venait d’un condensateur en court-circuit. Maintenant le mac remarche mais il me reste à remplacer le défaillant.
The problem was a shorted capacitor. Now the mac works again but I still have to replace the faulty one.
Was dit antwoord nuttig?
Het nuttigste antwoord
Have you tried just replacing the PRAM battery?
Afbeelding
You may need to take the logic board fully out so you can inspect the other side. Look for a component that looks discolored or burnt. Often the electrolytic & tantalum caps breakdown. Mac mini Model A1176 Logic Board vervangen
Score 1
5 opmerkingen:
@danj Hi, thanks for your fast answer. Is it possible that the mac could not turns on due to an issue with the pram battery ? Also, as i saw, i didn’t manage to find some dead caps on the logic board, the only thing that i noticed it that a ceramic cap looks weird near the cpu, it is a bit brown not as usual. So i used my multimeter to test for continuity and i have a value of more than 1100 on the line and this seems weird. Thanks
door Deel
@anthony10006 - The older systems need the battery to work properly. I would start there.
door Deel
@danj hello, i found a dead capacitor and now the Mac works. But i can’t find a schematic for this model. Have you got one please ? It’s 820-1900-A for the board model. Thanks
door Deel
@anthony10006 - Sadly I haven't found any for the Mini's. Best to ID the cap's specs how about posting both images of the cap and the location on the logic board. Voeg afbeeldingen toe aan een bestaande vraag
door Deel
@danj ok, i will send the image in the answers
door Deel
Voeg je antwoord toe
Correia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 673
