Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
583 Vragen Bekijk alle
Battery lasting 6 hours - is this normal?
I’m running Mohave 10.14 OS on a mid 2012 15” MacBook Pro unibody. I’ve upgraded my RAM and HD to an SSD and added a new battery in March 2021. I’m within a year of the installation of this latest battery and I’m only getting 6 hours from it. Is this normal? I’m reading email messages and news articles and have already lost 55% of my charge within 3 hours. Apple has taken away my ability to run command D for diagnostics. I have several tabs opened in Safari and have several apps up but not using. The Activity Monitor jumps around so much I’m not sure if one app is hogging the resources, Mail and Safari Networking seem to have the biggest numbers, 400+ MBs.
Is dit een goede vraag?
3 opmerkingen
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
@danj Thanks for the app. There was also something in in About or Preferences that showed the hardware/firmware for the battery but I haven't found it yet. I'll keep searching and see if it shows anything.
door
@paintslinger88 - Not needed here.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Well this batteries health is not very good! As an example my battery in my 2012 15” system looks like this:
You do need to charge your battery and look at how you are using your system. Are you running the system down fully than charging? If you are that will wear the battery out quicker. Instead when the battery is around one third plug it in.
Calibration is really only needed with a fresh battery and only if you are what I call a road warrior who needs to travel. If not its not really needed as over time the system will learn the minimum and maximum levels.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I don't discharge enough when I plug back in. Because it drains so quickly I even leave it on the charger for long periods. I'll try the recalibration to see if it buys me more life. Thank you for your help.
door
Did you ever properly calibrate the battery after installing it? Where did you purchase the battery from?
Apple MacBook Battery Calibration
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
Score 1
3 opmerkingen:
@gstan I did calibrate it when I purchased it from iFixit. I’m in the process of recalibrating it again. Thanks for the instructions.
door
May be the battery; I’ve had issues with the batteries purchased here unfortunately.
door
@gstan This is the second battery I purchased from them that didn't last a year. The first one had known issues (that I didn't know about) and they would have replaced it but I was outside of the window when I reported it. Where do you purchase your battery from?
door
Voeg je antwoord toe
M Zmerzlikar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 92
