Ga door naar hoofdinhoud
Reparatie-informatie voor de Asus Transformer Book T100TA. Uitgebracht in ~2013. Modelnummer: T100TA.
Connection of keyboard only to another computer
The battery of my Asus T100ta died completely. There is no way to charge it again or to turn it on even when it is plugged in. As the keyboard dock also served as a storage unit, there are some things I would like to get back from it.
Is there a way to connect only the dock to another computer via a USB port to recollect the data from it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @me746 ,
According to this supplier the laptop has a 2.5” sata HDD installed, which I assume is in the keyboard, the tablet part having non removable eMMC storage.
Perhaps it would be easier to remove the HDD from the keyboard and connect it to a PC via a suitable USB or sata adapter, (supplier example only to show types of adapters available).
I realize that the video I linked is for a T100 and not a T100TA but hopefully it is similar in concept to remove the HDD from the keyboard
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thank you, yes I have thought of that.
The keyboard is very similar, if not the same, so of course it is a good possibility.
I was actually wondering if the connection of the whole keyboard is possible through some kind of cable (with a USB end) so it could be used on another tablet or a computer.
Maybe I'm hoping too far and removing the HDD would be better.
door
@me746
You would have to know the pinout connections of the docking connector between the keyboard and the tablet so as to know how to access the HDD in the keyboard with an appropriately wired adapter cable etc.
For this you would need the schematics (I can't find any for the laptop) and then also find (or make) the adapter to suit etc.
It is much simpler to remove the HDD as after that it is straight forward how to connect to it and access the data as this is often done when removing HDDs from dead laptops to access the data
door
Since I am looking for a keyboard with a SATA port in it for my T100TA; I wish to know are you still keep your keyboard and can you sell it as a spare part to me?
My email : png270@gmail.com Thanks.
door
Voeg je antwoord toe
Sonia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 795
