Ga door naar hoofdinhoud
De eerste Altima werd geproduceerd in juni 1992, als een 1993-model. Alle Altima's werden gebouwd in Smyrna, Tennessee, tot juni 2004, toen Nissans fabriek in Canton, Mississippi ook begon met het produceren van dit model om aan de grote vraag te voldoen.
has problems starting most of the time
I have a 94 Nissan Altima 4 cylinder that has problems starting most of the time. If I pull a plug out I am getting spark and it allows the car to start, but put it back in then it doesn't start... Help please...
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Dave Scott could be many of things. If it has spark it most likely has spark when it is back in the cylinder head. So that would leave either fuel or air as a possibility. Check your fuel filter and pump to make sure that you have the right fuel pressure on that. The other thing you need to check for is that the spark happens a the right time. So you need to check the crank position as well as the cam position sensors. I would strongly suggest that when it runs, take it where they can scan the vehicle 's OBD to see if and what codes you get. Otherwise you might be spending a lot of money for parts that are not needed. Depending on where you are, places like Autozone do the scanning for free. Let us know what the exact engine is and what you have checked so that we may provide a more in depth answer
Was dit antwoord nuttig?
3 opmerkingen:
I have replaced the fuel pump, battery, and fuel injectors it is getting gas, also should note that after replacing each the car started like the problem was fixed I shut it off came out next morning back to not starting, has me very confused. Was going to take it to shop down the road but won't start now..
door
Sorry, forgot to also mention the spark plugs and wires were also changed recently.
door
What about the cap and rotor?
door
Voeg je antwoord toe
Dave Scott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 471
