Ga door naar hoofdinhoud
Reparatie- en probleemoplossingshandleidingen voor de Asus Republic of Gamers Strix 15,6-inch gaminglaptop met modelnummer GL503VM-B17N13.
Guide for re-pasting and cleaning
Hello,
I bought my Asus ROG GL503GE back on November, 2018. Since the last couple of days, the left CPU fan is making a faint buzzing sound, and the temps aren’t that great as those were before. I am thinking of cleaning and re-pasting my laptop. I am planning to use Noctua NT H1 for repasting.
So here are the questions:
1) Should I use isopropyl alcohol to rub off the old thermal compound? I heard some say that using alcohol might damage CPU linings (don’t know what they mean).
2) After disassembling the laptop and removing the power connector, is it a good idea to press the power button to drain the leftover charge from the capacitors inside?
3) Which order should I remove the screws from the heatsink? Are there any numberings on the screws?
I haven’t messed around with disassembling laptops that much. I would like to know the proper guide to remove various connectors inside the laptop. If there is any good thread/video about that, please share :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Anwarul Bashir Shuaib use this guide for the thermal paste Aanbrengen van koelpasta I would definitely perform a discharge you listed with 2. You will be okay with pretty much going in any order to remove those screws.
Was dit antwoord nuttig?
Voeg je antwoord toe
Anwarul Bashir Shuaib zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 671
