Ga door naar hoofdinhoud
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
170 Vragen Bekijk alle
Cant press play on xbox one game Mr.funnys toy shop?
Cant press play..on xbox..to play Mr funnys toy shop
Is dit een goede vraag?
Score 3
8 opmerkingen
Hi Chris. Could you provide some more information regarding this?
door
Grandson has new xbox.on some games..including above one..where it says ‘play ‘ on screen..u can't actually click on the word to play it. Tried ALL the buttons..even in different patterns
door
@chriscad Did you also tried a other controller? Looks like it's software related (could also be a hard disk issue). Is it modded?
door
Brand new.came with one controller. Font think it's a fault..just can't figure it out.thanks anyway.happy new yr
door
Looks like a software fault yeah. Perhaps a mod got stuck (if it's modded).
door
3 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
So for some reason the play button is not working when your trying to play the roblox game Mr. Funny’s Toy Shop:
Since this is a new xbox, and new controller, then that shouldn’t be the problem I’m suggesting that it might be a glitch since its occurring with other games. I recommend resetting your Xbox, here’s a video that might help: https://youtu.be/U8T9CMqmmK0?t=7
If the problem is still occuring, I then suggest to reset the actual controller, here’s a video that might help: https://youtu.be/dRSvLSK9Tc8?t=17
Since you tried all the buttons, this is actually a pretty common glitch, here it happens to a guy where he try’s to play Halo and he also shows how to fix this problem: https://youtu.be/uTV5WqMY20g?t=10
You could also check the Xbox status page. If you see any services with alerts, expand the service, scroll down to Notifications, and sign in to receive a message when the service is up and running again. Or you could also restart your PC. On your PC, press the Windows button, then select the Power button, then Restart. If the PC appears to be frozen, press and hold the Power key on the device for 10 seconds, until the PC turns off. After it shuts down, press the Power key to restart.
If the problem still occurs, I suggest you look through the manuals and Contact Xbox for support at: https://support.xbox.com/en-US/help/hard...
Hope this helps :)
Was dit antwoord nuttig?
Score 1
Some roblox games do this I think it's because roblox is primarily a PC game so the game was designed to be used with a mouse
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,379
