Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Handleidingen en reparatie-informatie voor de LG Exalt VN220. De LG Exalt VN220 (ook wel de LG Exalt of Exalt LTE genoemd) is een klaptelefoon die in 2018 werd uitgebracht.
My screen is black
My phone is working but the screen is black
Is dit een goede vraag?
Score 1
2 opmerkingen
Might I ask what you mean by working, and what troubleshooting steps you have followed so far?
door Deel
@isaac8183999 yep, sounds like a bad screen
door Deel
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
Maybe consider trying to find a replacement screen or taking it to a expert to determine if the screen has become damaged somehow.
Was dit antwoord nuttig?
Score 1
hi, I'm a technician specializing in Vn220 repair, if you find your screen blank the most common cause is the yellow belt or wire who sends info & electricity to the screen has cut off, so the first step is to replace that wire, secondary, make sure the battery is not the problem by inserting another working battery and see if it turns on,
Score 1
8 opmerkingen:
is there any way to obtain pictures from this phone without repairing the screen? We have taken it to a phone repair shop and they cannot find this part anywhere. (According to them)
door Deel
@luzer wanna help me with this phone?
door Deel
@escajeda32 If you enabled USB Debugging, that would work to connect your device to your computer or use scrpy. Though the best bet would be to find another phone and swap bottom boards to see the screen to take off whatever you like.
door Deel
@yifi What do you need help with?
door Deel
@fixmylgexalt replying to my post from a year ago... Think I still remember???
But thanks anyway. Also, it says in your profile that you sell these parts.
I might be interested in buying...
door Deel
3 commentaren meer tonen
I wanted to offer my expertise. I am a technician and have successfully repaired over 100 of these devices.
If you're experiencing a black screen, the issue could be due to one of the following:
1. Flex cable
2. PCB (printed circuit board)
3. LCD
4. Connector on the motherboard
You can find all the necessary replacement parts at primephoneusa.com, which also offers repair services.
Score 1
Voeg je antwoord toe
Sarah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 32
Altijd: 1,755
