Ga door naar hoofdinhoud
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
56 Vragen Bekijk alle
Samsung TV dead, no standby light un65mu8000 NOT ABOVE LISTED TV
Hi. after combing the diy sites, here is what I’ve come up with. I have Power board BN44-00912A AND MAIN BOARD BN94-12295K.
When I unplug the main board from power board the Back lights WORK. There are 2 cables running from power board to main board.
I replaced the mainboard but this didn’t fix anything (might be DOA but not sure)
I have checked power on the power supply board but there is no pin that is clearly marked STANDBY to look for the 3.3 or 5v.
There are 20 pins on CNM803. The first 5 are GND. The next few are VAMP (not sure what this stands for).
Then they pin out like this:
OD_LEVEL,
FAIL_COUNT
OD_ON/OFF
BLU_ON_OFF
POWER ON/OFF - (i checked this its at 4.5v)
PINS 11-17 A13V PINS 18-20 GND
Is dit een goede vraag?
2 opmerkingen
Thanks for the help. Here are the values from the CNM803 cable connector.
WITH = with MB connected
WO    = without MB connected
CNM803          WITH       WO
1. GND              0         0
2. GND             0           0
3. GND             0          0
4. GND           0               0
5. VAMP           9              12.85
6. GND             0                0
7. VAMP              9             12.85
8. OD_LEVL        0           3.2
9. VAMP                    9          12.85
10 FAIL COUNT     0         13
11 A13V                    9           12.85
12 OD ON OFF     0            3.2
13 A13V                    9           12.85
14 BLU                      0             3.2
15 A13V                    9             12.5
16 POWER ON/OFF        96       4.5
17 A13V               9        12.85
18 GND                 0        0
19 GND                 0         0
20 GND                 0          0
door
Well, almost good news.
I got a used mainboard. Installed it. Power is on and picture is up BUT half the screen is darker on one side (some faint lines going from top to bottom on left side of screen when screen is black)
Also, the remote only turns the TV on and off. No other functions. I tried taking out batteries and holding power button to reset but it didn't work
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @rgla
The 7.5V standby voltage reference test point is marked on the board.
(click on image to enlarge)
Here’s a link that may also help with troubleshooting the power board.
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
Thanks. How do you test on that pin? set meter to VDC and ground black probe on body of tv and touch red probe to pin?
door
@rgla
That's right.
Screwhead of screw holding board to chassis is usually a good earth.
Also measure anywhere along that jumper strap will do.
Be aware that sometimes the jumper may have developed an oxidized coating so you may have to rub the probe along the jumper a bit to get through to the "bare metal" so to speak just in case you don't initially get a reading.
Be safety aware as there is exposed lethal AC voltage on the "hot" side of the thick black line on the board
door
Thanks. I checked the jumper strap. I can't turn on the TV but I plugged it in. here are the readings I got.
9v with Main Board cable plugged into power board
12.85 with Main Board DISCONNECTED from power board
door
Pin 16 Power On/off: shows 96 volts with the main board connected and 4.5 without. 96 seems way high. Could a short be causing that much voltage with the MB connected? 4.5 without seems about right
door
got a used MB. Put it in and it powers up.
BUT half the screen is darker than the other. What now?
door
1 commentaar meer tonen
Voeg je antwoord toe
rick irons zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 715
