Ga door naar hoofdinhoud
Wherever you go, bring some big beats with you. The SRS-XB10 is easy to carry and gives your music some extra bass.
Replacement interior plastic brace/bracket with screw holes for XB12?
My Sony XB12 dropped and upon opening the outer shell you can see that the interior brackets snapped, everything else is okay and fully functional. Now the screws have nothing to screw on to and keep it closed, much less watertight.
Where can I find replacement brackets?
EDIT: both of the screw stems of the bracket, where the battery is attached, are capped and one of the mounting holes from the board bracket is obliterated while the other has three cracks and with any force will also split open.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@j053 . We would have to see what this all looks like. Looks like 2 of the screws go into extension “legs” from the battery case and two go onto some plastic fittings on the main board. We would have to see what this all looks like. Parts are not readily available so you would need to either purchase a broken speaker and harvest the parts from that or see if anybody can do some 3D printing for you.
Post some good pictures of where the crack is and which bracket you are referring to, with your QUESTION. Voeg afbeeldingen toe aan een bestaande vraag That way we can see what you see.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I have updated with pics.
door
Voeg je antwoord toe
Jose Jimenez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 243
