Ga door naar hoofdinhoud
A1418 | EMC 2889 | Late 2015 | 1,6 GHz dual-core Intel Core i5 of 2,8 GHz quad-core Intel Core i5. Uitgebracht op 13 oktober 2015.
What does blinking LEDs 1 and 2 mean?
iMac 21.5” does not power up, no chime is heard. I know that LED codes are: LED 1 on= trickle voltage from power supply is detected by logicboard. LED2 on= logic board has detected proper power from the power supply when the computer is turned on.
The problem is BOTH LEDs 1 and 2 are BLINKING (not ON continuously) when I connect the AC power cable to the mains wall socket. What problem does this point to?
Is dit een goede vraag?
Score 2
4 opmerkingen:
Can you offer some additional details on what preceded things here.
door
Nothing unusual happened prior to. Thing just suddenly won't turn on.
door
Where is the light coming from?
door
Light comes from the vertically arranged LED array on the logicboard.
door
Voeg een opmerking toe
1 Antwoord
What does the other LED’s telling you?
Afbeelding
Did you try reseating the RAM? Did you replace the RAM you might have a bad SO-DIMM.
Was dit antwoord nuttig?
3 opmerkingen:
The RAM is permanently soldered to the logicboard in this model, and cannot be replaced.
door
Dan, when I press the power button, the 2 other LEDs remain unlit, #1 and #2 LEDs turn off. When I release the power button, LEDs #3 and 4 remain off and #1 and #2 start to blink again.
door
@Bernie - Sorry your right! One of the few iMacs with soldered RAM.
I think your logic board is blown then.
door
Voeg je antwoord toe
Bernie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 512
