Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Vragen Bekijk alle
No boot, black screen after cpu change
Hello,
After I changed the CPU on my iMac 2010, from i3-550 to i7-870, I get a black screen. I hear the fans turning on and off continuously. I have tried to go back to the i3-550, but it’s now the same issue, whether I boot with the i3-550 or i7-870.
Thank you in advance
Update (08/23/2021)
Sorry for commenting back a week late, I’ve been busy.
Here are the pictures of my socket
Is dit een goede vraag?
1 Opmerking:
I don't see any damage I also don't see any signs of thermal paste. So clearly you either did a good job not getting it all over or did a good job cleaning it up. Don't forget you need to put a small amount on the heat spreader cover, don't let is ooze over the edge.
door
Voeg een opmerking toe
1 Antwoord
Are you sure you didn’t damage the socket or something else in the process?
At this point you need to go back to the chip and this time take pictures so we can see what you have Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Voeg je antwoord toe
Peter Christian Therslund zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 60
