Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
20 Vragen Bekijk alle
sound will only come on during charging
I keep losing all sound on my iphone 3gs the only way to get it back on is to turn it off and charge it for about 10 mins or so and leave it connected while i turn it back on and the sound will come back. but after a while when i disconect the phone it loses sound again. i have tried factory settings and and all the other tricks posted about to no help... it seems to lose all sound when i press the home button or plug the charger in again. anyone have any clue to whats happening?
Dave
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It might be the dock connector assembly in bottom of phone. The Home button, when pressed, makes contact with contact points on top of dock connector. Your USB cable plugs into dock connector port. Your speaker is also housed in it as well.
It would probably be around $10.00 to replace.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Chuck is probably correct. First however, I would try to clean the iPhone Dock Port very well with some Isopropyll Alcolhol, clean especially the pins which are on top of the Dock Midrib.
door
Voeg je antwoord toe
david zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 548
