Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht op 23-10-2003, productnummer A80.
How to replace the ccd sensor
i need to replace the ccd sensor from my canon a80
(i have already the guide about removing the back cover)
many thanks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
ra1969monm you can download the complete Canon service Manual from here It will show you how to dismantle, repair and adjust your camera. There is also a good video right here on youtube Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
11 opmerkingen:
thank you very much!
door Deel
You are very welcome :-)
door Deel
Hi Oldturkey,
Just ordered the CCD for my A80 and was looking for a service manual to get a heads up on the disassembly procedures. That led me to finding your post.. I have registered with KeepandShare, but I need your permission in order to download the manual. If you could see your way clear to add me to the allowed list I would be much obliged.
Also.. saw your post on wanting to find a replacement output transformer for a tube amp. I can definitely help you there, but will need more specifics on the unit.. brand/model number/output tube(s) type etc.
Thanks!
door Deel
can I get your permission too? I have a non functioning A80 that I am trying to fix?
bc_tbcvideo
Thanx.
door Deel
6 commentaren meer tonen
these links are all gone. anywhere else we can find them - i need to replace senors on a70 , a80 and an a610
Voeg je antwoord toe
ra1969mon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 6,404
