Ga door naar hoofdinhoud
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
aux in is broken ,how can it be fixed
aux in is broken ,how can it be fixed ? do i need some Accessories
Is dit een goede vraag?
1 Opmerking
@boseman how is it broken? Is the connector physically broken or what is going on with your Bose?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@boseman take a look at this guide. Step 6 shows the port soldered onto the board. So it would not be easy. You could try and purchase a broken Bose SoundLink Color and harvest the port from it. Or you could possibly pigtail a separate input port (cable) to it. This will depend on your soldering skills etc. If you can, post some images of the damage (disassembled) with your question. For that use this guide. That would allow us to see what you see and possibly point out where to solder to.
iFixit Afbeelding
Handleiding
Voeg afbeeldingen toe aan een bestaande vraag
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Bose SoundLink Color Speaker Afbeelding
Handleiding
Bose SoundLink Color Speaker Replacement
Moeilijkheid:
Moeilijk
20 - 30 minutes
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I have uploaded several pictures of it.
Ccould you help me to see whether i can fix it by using the old aux and just fix it (not replace ),
door
@boseman Looks like the walls on the jack have actually cracked. so that would not be something that can be fixed but would require some sort of replacement.
door
Voeg je antwoord toe
Kyle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 714
