Ga door naar hoofdinhoud
Released in June 2016 with the internal code name of GP104-200-A1, the GTX 1070 features 7.2 billion transistors along with 8 GB of GDDR5 video memory.
Why isnt my monitor detecting my gpu?
  1. I’ve replaced my video card, tested my monitor on a different computer, and used different cables. I have no idea whats wrong.
  2. ( the device selected isnt my actual gpu, it was just the only one i could choose. my actual gpu is geforce gtx 1660)
Is dit een goede vraag?
3 opmerkingen:
try checking supply voltage
door
Have you tested the GPU on another computer to see if it actually works?
door
If it does work then try reflashing the bios
door
Voeg een opmerking toe
2 Antwoorden
A monitor does not detect a GPU. The GPU does the detection. A single wire tells the GPU a monitor is connected to the port. The GPU then queries the monitor.
Since you replaced the card, verified your monitor works on a different computer, and used different wires then it must be a driver issues.
Was dit antwoord nuttig?
1 Opmerking:
what would a driver issue mean? can it be fixed?
door
Hi,
What is the make and model number of the PC or motherboard if a custom build?
Is the PC booting up OK, you didn’t say?
If not booting up connect a PC system speaker (example only) to the motherboard speaker header pins and check for any beep error codes, (different BIOS makes).
Maybe the PC is not passing POST. Check the motherboard’s user manual for the location of the speaker header pins on the board. Also the BIOS make should be listed as well
If the PC boots OK, does the motherboard have onboard video i.e. CPU with integrated graphics and video output connector (HDMI, vga etc) on motherboard?
If so remove the GPU card and connect the monitor to the onboard video and check that it works OK.
Voeg je antwoord toe
aevuh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 620
