Ga door naar hoofdinhoud
Teardown information for the Nespresso CitiZ coffee machine. They are available from different brands, e.g. Krups, DeLonghi.
8 Vragen Bekijk alle
Nespresso CitiZ coffee machine, some water is leaking into collection
I have a Nespresso CitiZ coffee machine and some water is leaking into the collection tray without passing through the coffee pod. I assume that an internal seal has worn out. How easy is to renew the seal and from where can it be sourced?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hi @kaput43,
Here’s the Ifixit Nespresso CitiZ Teardown guide that should be of some help.
Here’s a link to the parts for the machine.
Once you have found the problem search online Nespresso (insert part number) to get results for suppliers that suit you.
Looking at the Exploded View1 pdf document at the top of the parts list it appears as though the machine is a rebadged De Longhi machine. This corresponds with the part numbers when I searched for a few parts by using the above method, as the results were also for De Longhi machines.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Those parts prices are ridiculously high! I'll probably just buy a new unit.
door
Probably the brewing unit needs to be replaced. Here is the guide from iFixit (in German). The spare part costs about 25€.
Score 1
Firstly, kudos to you for taking the initiative to fix the leakage issue yourself. It's always great to try troubleshooting before seeking professional help. However, I couldn't find the specific guide you mentioned. Nevertheless, here are some general steps you can follow to address this problem:
  1. Double-check the water tank.
  2. Inspect the seals.
  3. Descaling the machine.
  4. Check the drip tray.
  5. Run a water-only cycle.
Voeg je antwoord toe
Graeme zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 324
Altijd: 5,969
