Ga door naar hoofdinhoud
Repair guides and support for Dell Netbooks, a class of small, lightweight laptop computer from the late 2000s.
17 Vragen Bekijk alle
My Inspiron 7579 is crashing. Help.
The computer is crashing and BSOD always shows up. I’ve tried blowing on the fan, but it didn't help. help
Is dit een goede vraag?
1 Opmerking
Provide a image of the BSOD or the error code, photo would be more useful
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
BSODs are usually software-related. Try resetting your computer by going to Settings -> Update & Security -> Recovery. Under the Reset this PC, choose Get started. Follow the prompts.
This will remove your apps and settings, but may prevent further crashes.
Was dit antwoord nuttig?
I am going to say that by you laptop crashing, then it does come up. If so go to Event Viewer and then Window Logs and see what might be causing the issue. Also the BSOD error would be helpful. Check to see how much RAM you are suppose to have verses how much RAM your system is showing you have.
First take a data backup of your important data now try reset the settings of your laptop as it was new. If it didn’t work then just change the window of your laptop.
Voeg je antwoord toe
normal person zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 95
